How to edit the appearance of one instance of a type def (not strict)?
I would like to edit the appearance of a control (changes which require using the LV control editor).  Unfortunately, this control is an instance of a (non strict) type def.  How do I do this, without editing the appearance of the type def itself?
Jaegen
(2,909 Views)
Hi Jaegen, this worked for me...
Open the typedef - don't worry, you aren't going to _save_ changes
Edit typedef as needed
[When done editing] copy connector-pane (select, ctrl-C)
File\Revert !!!
Select target-control and paste!
In LabVIEW 7.1, the edited/pre-reverted ... ouch ... control appears (and still connected to typedef).
Message Edited by Dynamik on 11-16-2005 08:22 PM
Message Edited by Dynamik on 11-16-2005 08:23 PM
Message Edited by Dynamik on 11-16-2005 08:24 PM
When they give imbeciles handicap-parking, I won't have so far to walk!
(2,904 Views)
