How to dynamic change the appearance of donzen of control of the same kind?
I want to change the appearance of a donzen of LED control in the panel by
program. How to realize it through a for loop without explicit change the
value of every control?
(3,080 Views)
You may create a control reference for each LED and collect all references in an array.
Feed a for loop with this array and use property nodes to change value and appearance of all LEDs.
Paolo
Paolo
(3,070 Views)
Thanks.
(3,063 Views)
Pincanter,
COuld you also typedef the control and then make a change to one of them instead of all?...or can typedefs not be changed in runtime?
Hell, there are no rules here...we're trying to accomplish something!!! - Thomas Edison
(3,057 Views)
You can do the same with custom controls, too.
If I correctly remember, there are some limitation with strictly typed controls when you try to change things like colors and other appearance properties.
Values can always be changed, though.
Paolo
Paolo
(3,051 Views)
