Option 3 was the important one and I meant you should try deleting other stuff (not the filter event) as much as possible.
Would this still happen if you delete everything but that control and that event (not start from scratch, like you did, but delete from the existing VI)? If not, then that is not the only source, and that's why you should delete different parts until you find what else causes it. Once you come up with that, it should hopefully be far enough from your original VI, and you will be able to post it.
___________________
Try to take over the world!
