I have attached an example, its actually an example found in the labview examples folder "examples\viserver", but slightly modified and turned into an exe file. The dynamic VI's are not included in the build.
I have saved out, using the Save with Options, one of the plugin VI 'Create Data Set.VI' plus sub-VI which are usually found in the vi.lib\analysis folder.
This backs up what I initial said plus Dennis and DFGray's comments.
Its a LabVIEW 7.0 example
Hope this helps
Ray Farmer
Ray Farmer
