Some questions about install and use ivi driver for ke2000
I have install ivi driver for ke2000, i think the setting in the MAX may got somthing wrong,it only can used when choose  ""simulate with specific driver" under the option of "Driver sessions",but when I choose  ""simulate with Dont Simulate" under the option of "Driver sessions",error will come out.
anyone can help?
Cheers,
Nicosg
anico2127@yahoo.com.sg
Message 1 of 13
(4,549 Views)
help can be told step by step. thanks
Cheers,
Nicosg
Message 2 of 13
(4,543 Views)
Hello Nicsog,
      Help certainly can be told step by step and we have some wonderful documentation on IDNet that does just that.  The most pertinent tutorial is:
Getting Started Using National Instruments IVI with LabVIEW or LabWindows/CVI
Pay specific attention to Step 7 in the second section:
..." Otherwise, select Don't Simulate and create a new hardware asset under the Hardware tab."
Have a grand Friday,
NathanT
Message 3 of 13
(4,537 Views)
I will try that,thanks a lot
Cheers,
Nicosg
Message 4 of 13
(4,519 Views)
I am trying to communicate with my equipment ,that's why i am using "don't simulate" ,How to start communicate with my Ke2000t by loabviewproject,where should i start first??
Cheers,
Nicosg
Message 5 of 13
(4,512 Views)
not easy leh.
帖子被nicosg在08-05-2007 10:34 PM时编辑过了
Cheers,
Nicosg
Message 6 of 13
(4,510 Views)
Hi,NathanT
I am trying to follow the linked website you have gave last friday, as I am quit new in labview area,i face some problems again,
At step4, i cant find the "driver sessien" which i want after I create a new logic name.
one more stupid question,I am not so sure what is the meanning of "Expand IVI Drivers." in step 2,is that means just run the correct msi document in the lv project?
thanks
Cheers,
Nicosg
Message 7 of 13
(4,505 Views)
How to "Expand" IVI Drivers. ?
Cheers,
Nicosg
Message 8 of 13
(4,498 Views)
You can expand the IVI drivers by selecting the + sign.  After you create the logical you select the driver session you want to use.
Message 9 of 13
(4,471 Views)
Hello nicosg,
      Lets limit the discussion of this issue to this thread, so we can all follow it and others can benefit from it.  I posted a link to this thread to the other threads that you started on this topic which can be found here and here.  You need to add your instrument under the hardware tab of your driver and make sure the field under the Resource Descriptor is populated with the correct resource for your instrument.  You should be able to double click on that field and enter the resource descriptor (GPIB1.....etc).
Cheers,
NathanT
Message 10 of 13
(4,466 Views)
