05-03-2007 07:21 AM
05-04-2007 05:19 AM
05-04-2007 05:32 AM
05-04-2007 09:46 AM
05-04-2007 10:28 AM
05-08-2007 05:16 AM
Other information which may be relevant.
I have enabled the device to work with NI 488.2 compatible programs in the Agilent Connection expert.
I am able to program connected GPIB devices through a VISA test panel from MAX.
If i try to run the example code (Template - Function Generator Standard Waveform.vi) for an attached device (eg. Agilent 33250A) there are no options in the VISA resource name drop down menu. If i try to add a resource name by hand LabVIEW crashes!
05-08-2007 11:17 AM
05-08-2007 11:37 AM
Hi Jon,
Maybe i'm missing something obvious but i cannot find the visa I/O filter. I've attached a screen grab of what i get.
05-09-2007 03:56 AM
05-09-2007 04:50 AM
Hi Jon,
Changing the visa I/O name filtering has no effect, there are still no option appearing in the pull down menu. When i enter GPIB0::10::INSTR by hand, LabVIEW just hangs and then when i try to stop the vi running i get the windows -program not responding error message. As you suggested, i have tried running a simple write and read vi (from \LabVIEW 8.2\examples\instr\smplserl.llb) and pretty much the same happens. The only difference is that the visa resource name box is not blank but has COM1 instead.(or COM4 and COM5 in the case of Basic 2 Port Serial Write and Read.vi).
Many thanks
Kevin
