Hello. I am using linux kernel 2.6.16.18; I modified the driver
in NI-488.2 verson 2.3 to compile; I changed remap_page_range to
remap_pfn_range and fixed the pfn argument.
However the shareable libraries don't work. If I build a
HelloWorld program that links to libgpibapi.so, the program aborts (as
does a simple program similar to the example).
strace shows it may be aborting on loading the shared library and have
something to do with a mismatched GLIBC. Is a new version of the
driver due soon?
The 2.6 linux kernel had too much churn to remain compatible with your driver.
I am building the 2.4 kernel to use the old 2.2 driver which had worked OK.
Also, what does it mean when the NI applications say "Unable to open resource files."?
