01-12-2006 05:51 AM
01-12-2006 08:53 AM - edited 01-12-2006 08:53 AM
Message Edited by Dennis Knutson on 01-12-2006 07:54 AM
01-12-2006 09:32 AM
You can download Agilent IO Libraries at Agilent web site. The latest version is IO Libraries Suite 14.1.
http://www.home.agilent.com/cgi-bin/pub/agilent/Product/cp_Product.jsp?NAV_ID=-536897828.536894874.0...
The "Suit 14.1" is little bit heavy for low-power PCs and there was the 2nd latest version - Agilent IO Libraries M01.01 which was bit light. However, the old versions all have been discontinued thereby the only available version is "Suite 14.1". The SETUP program of this installs both Agilent VISA (= HP VISA) and SICL. The latest version requires WinXP/2k and .NET Framework.
Supported GPIB/HP-IB hardware is documented in the following version info table:
http://www.home.agilent.com/upload/cmc_upload/All/Interface.htm?cmpid=92959
01-13-2006 04:13 AM
OK, thank you for your help.
I try to use it now and will inform you if evrything is OK
01-18-2006 03:53 AM
Hello
I can now communicate with the HP35660A via NI GPIB-USB-HS. I used HP-VISA (found it in I/O suite 14.1) and not NI-VISA.
But I don't found a Labview driver for this device. (it doesn't exist in Labview and Agilent driver databases).
Has somebody develop a Labview driver for the HP35660A? (or in another programmmation language?).
Thank you for your help
12-20-2007 06:11 AM - edited 12-20-2007 06:13 AM
12-20-2007 06:57 AM
12-20-2007 07:28 AM
12-20-2007 09:33 AM
Sorry, you are right that the original poster also had an NI controller. It was the other device that required the Agilent driver I believe.
The 53131A is a modern instrument and does not require any software from Agilent in order to be recognized. I don't think the 53131A requires anything to enable the GPIB port but that's one thing to look for in the manual. You could also try a different cable or try connecting a different instrument. First, though, you want to make sure that there is nothing left of the Agilent software and that MAX recognizes the NI controller and that all of the tests pass for the controller itself.
12-20-2007 10:45 AM
