10-12-2009 04:09 PM
Solved! Go to Solution.
10-12-2009 04:19 PM
Hey Garrett,
This is not possible. A node can only be connected with one gateway at a time. You can configure nodes as router nodes, which allow them to dynamically mesh with each other and form other altnerate routes back to the gateway.
Let me know if you have any other questions!
Kevin
10-12-2009 04:23 PM
10-12-2009 04:27 PM
Hey Garrett,
In this situtation, you would remove the node serial number from the gateway in Measurement and Automation Explorer (MAX), and add it to the new gateway in MAX. You would then power up the node in its new location, and reset its network channel by holding the signal strength button down for 5 seconds. This will allow the node to join a new network.
Kevin
10-12-2009 04:29 PM
So it sounds like the same instance of MAX software controls, or can control, multiple gateways...is that correct?
Garrett
10-12-2009 04:32 PM - edited 10-12-2009 04:32 PM
11-05-2009 07:29 AM
If we did have a measurement node that was assigned to a gateway, and someone else set up a different gateway (using a completely different copy of MAX software) and tried to add that node's serial number to the new gateway, what would happen in that case?
Garrett
11-05-2009 12:37 PM
Hey Garrett,
There are a two scenerios here, so let me see if I can address each one.
Scenerio 1
Note: If Node A is factory reset or told to disconnect, there is a chance Node A could find Gateway B before finding Gateway A. In that case, Node A would join Gateway B, and not rejoin Gateway A.
Scenerio 2
Let me know if you need any further explaination.
Kevin
