VeriStand
Veristand deployment error -307742
During veristand deployment im facing following error
Deployment Error
Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
<append>=========================
NI VeriStand:  NI VeriStand Engine.lvlib:Launch VeriStand Engine (Win).vi.ProxyCaller >> NI VeriStand Engine.lvlib:Launch VeriStand Engine (Win).vi
NI VeriStand:  Make sure that NI-DAQmx and NI-VISA PXI support is installed. NI VeriStand Engine.lvlib:Launch VeriStand Engine (Win).vi.ProxyCaller >> NI VeriStand Engine.lvlib:Launch VeriStand Engine (Win).vi >> Launch Asynchronous VI by Path.vi >> sub Launch Asynchronous VI.vi
NI VeriStand:  Broken VI: NI VeriStand Engine.lvlib:VeriStand Engine.vi
Missing external function lvanlys.*:LV_Gamma_85:C in VI ni_Incomplete Gamma Function.vi.
Missing external function lvanlys.*:LV_Gamma_85:C in VI ni_Gamma Function.vi.
Missing external function lvanlys.*:LV_CosI:C in VI ni_Cosine Integral.vi.
Missing external function lvanlys.*:LV_SinI:C in VI ni_Sine Integral.vi.
Error -307742 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
Possible reason(s):
NI VeriStand: The VeriStand Engine could not be loaded. Make sure that NI VeriStand and the required drivers (such as NI-DAQmx) are installed correctly. Refer to the NI VeriStand readme.html for a list of required software and drivers.
(285 Views)
This question is best to be posted on the VeriStand board
As mentioned in the error message, make sure that all the dependencies are installed. Use NI MAX to check the list of software installed. Determine the Version of NI Software Installed on My Computer
Control Lead | Intelline Inc
(251 Views)
