VeriStand
Signal value is toggling on veristand screen(GUI)
The Test_Signal is present in dbc file and it's incoming signal for a component from controller side.
In dbc file signal has default value as 0, factor as 1 and offset as 0.
The value is togging very fast on veristand screen but on CAN bus monitor showing only one value which is 2 and on bus monitor value is not toggling.
Note: VeriStand version - 2017
please can you help me to why signal value is togging on veristand screen as we getting one value on CAN bus?
How can I resolve this issue, please help me.
Thank you!!
Message 1 of 8
(507 Views)
Is it a J1939 frame? What is the Arb ID?
Control Lead | Intelline Inc
Message 2 of 8
(476 Views)
it's not j1939 message.
Message 3 of 8
(467 Views)
If you log the entire bus activity using NI-XNET Bus Monitor, are you seeing the same data on that ID all the time?
Message 4 of 8
(459 Views)
yes, using NI_XNET bus monitor, getting same value for Test_Signal(respected message id of Test_signal ) all time which is 2 and expected value is also 2.
Values are toggling on veristand gui screen.
Message 5 of 8
(449 Views)
If the bus frames are logged while running VeriStand (Log Bus Traffic with NI-XNET Bus Monitor While Running NI-XNET Application), and yet displaying different signals, I cannot think of any possible causes. Perhaps try to upgrade your XNET driver to a later version.
Message 6 of 8
(431 Views)
I just want to update its j1939 message frame. Can we anything related to j1939 addon in veristand.
Message 7 of 8
(401 Views)
Use the latest release of Releases · NIVeriStandAdd-Ons/J1939-Custom-Device
I don't remember the exact name. There is a new checkbox added, allowing users to separate messages by source address.
Message 8 of 8
(389 Views)
