VeriStand
NI Veristand via ASAM XIL - MAPort: Expected latency on write?
Hi
Starting to evaluate using NI Veristand(2018) via ASAM-XIL (MAPort) and did some initial performance tests reading and writing values to aliases in the Engine demo using Python.
My current setup is running python using the ASAM-XIL API on one computer and Veristand on another, connected via Wifi.
Read averages on 1-2ms, sometimes slower ~6ms, something that seems rather ok.
Write is in the range 30-60ms which to me seems very slow given that the network added latency part of it should be less than 1ms.
Is this what one can expect?  Is there a obvious reason on why(update loops in Veristand?)? Other experiences or ways to improve?
Best regards!
Kristofer
Message 1 of 11
(3,750 Views)
Found a parameter to modify, greatly improving the latency, changed the "Data rate" setting from default 15Hz to 250Hz (anything above 250Hz gave basically no difference)
Read went down roughly 25%
Write went down to around 15ms, which I still consider a bit high for the planned usage scenario.
Anyway to improve even more?
P.S: NOTE: I have not tried against a running real time engine yet, this hopefully improves the latency even more (but that is yet to be proven)
Message 2 of 11
(3,655 Views)
Hi Kristofer,
I'm experiencing the same issue with the latency of the MAPort.
Could you please provide more information about how to modify that "Data rate" setting you found ? Is it a setting of the MAPort ? How can I access it ?
I couldn't find anything about that setting in the ASAM XIL documentation.
Thank you for your help !
Jeremie
Message 3 of 11
(3,610 Views)
Hi Jeremie
You can find it in the veristand .sysdef file(XML).
/Kristofer
Message 4 of 11
(3,603 Views)
Got it. Works fine.
I set it to 200Hz and I got something close to 5ms between two read values, which is consistent.
Thank you very much !
Jeremie
Message 5 of 11
(3,589 Views)
Glad to be able to help out!
Would hope some one with insight and expertise could help out elaborating on possibilities to improve even more (maybe someone from NI?)
BTW: Can you please check what write performance you get and reply?
/Kristofer
Message 6 of 11
(3,584 Views)
