09-05-2012 08:49 AM
I am trying to implement Lambda Genesys DC Power Supply custom devices , I have pxi 8108 with pxi1042Q ,and Lambda Genesys DC Power Supply, do I need any other hardware to communicate with power supply
09-06-2012 01:59 AM - last edited on 04-25-2024 03:55 PM by Content Cleaner
Hi Siddharth,
I see that Lambda Genesys DC Power Supply supports RS232/RS485 communication standard. If the model of programmable power supply that you have also supports RS232/RS485 communication then you need to have a PXI serial interface card.Please click here to browse various available options.
09-06-2012 04:23 AM
CPU |
Intel Core 2 Duo T9400 processor (2.53 GHz dual core) |
Dual-channel 800 MHz DDR2 RAM, standard |
1 GB (1 x 1 GB) |
Dual-channel 800 MHz DDR2 RAM, maximum |
4 GB (1 x 4 GB) |
Storage, hard drive minimum | 80 GB SATA |
Storage, solid state | Optional* |
Hard drive (standard option), minimum |
80 GB SATA (5400 rpm) |
Hard drive (extended temperature and 24/7 option), minimum |
10/100/1000BASE-TX (Gigabit) Ethernet ports |
1 |
Hi-Speed USB ports |
4 |
GPIB (IEEE 488) controller |
Serial port (RS232) |
Parallel port |
ExpressCard/34 slot |
Watchdog/trigger SMB |
Can we use RT controller serial port for communicating with power supply
