VeriStand
Error converting .mdl to .dll
I'm new to veristand, i have 2 questions
1)how to get started with veristand basics? i saw some demos but i really need a document explaining procedure of some model. If anything pls tell me.
2) I have created a model in simulink and i'm using 2010b version and 2011 veristand evaluation version. I'm not able to convert .mdl to .dll using real time worshop.
(6,075 Views)
I finally created a .dll file from .mdl simulink model. I configured in veristand and tried to deploy in veristand but i'm getting the following errors. So how do i get rid of this error.
(6,072 Views)
(6,046 Views)
I think this is a error due to configuration, you might want to check out this guide:
Creating Simulation Models Using The MathWorks, Inc. Simulink® Software for Use in NI VeriStand
http://www.ni.com/white-paper/13066/en
setting up The Mathworks, Inc. MATLAB® Software to Create a NI VeriStand Compatible DLL
http://digital.ni.com/public.nsf/allkb/D70E74FDA37CD8E486257990000603A0?OpenDocument
Generating Models from The Mathworks, Inc. Simulink® Simulation Software for Deployment on VxWorks Systems
http://digital.ni.com/public.nsf/allkb/9B38EF4AB0F5739A86257A29006D8E8C?OpenDocument
(6,042 Views)
Hi jay090909,
As indicated by the error message, you must install DAQmx Drivers on your local machine to deploy; the NI VeriStand Engine (localhost and RT) require this driver to execute. You may install the drivers from the Drivers DVD or from ni.com.
NI-DAQmx Full
http://joule.ni.com/nidu/cds/view/p/id/3423/lang/en
Nestor
(6,034 Views)
