01-09-2014 01:19 PM
I don't know if there exists a model parameter file. I did not create one, and started getting this error. Does anyone have an idea if there is a model parameter file that somehow got hosed, or if there is a parameter in the system definition file?
Thanks.
01-10-2014 10:50 AM
What program are you generating your model with? What version of VeriStand and/or LabVIEW are you using? Can you provide a screenshot of your error? Can you give some basic information about what your model is doing, and what kind of parameters you're working with? This information may help narrow down possible causes of this error.
01-10-2014 10:55 AM
Does this happen with a brand new system definition? It would help if you could attach the system definition that shows this problem. We shouldn't need the models or anything else, just the system definition.
01-10-2014 11:01 AM
You might make sure to uncheck "Apply parameter values from file at initialization" on the Simulation Models page, even if you don't have a parameter file specified.
