02-02-2024 02:36 PM
I have a Veristand project that uses the Scan Engine and EtherCAT custom device with a cRIO-9145 connected to a cRIO-9045. Someone bought NI-9262 cards which need the FPGA, so I want to know if I can use these cards in the cRIO-9145? I know I would have to create the FPGA code, but I don't know if I can add the FPGA target for the 9145 to my system definition.
02-02-2024 02:54 PM
If you look under your NI 914x chasses you will see User Variables. You can add the FPGA personality for for the 9262 cards there.
02-02-2024 03:06 PM
Thank you very much. Would I be able to run in Hybrid mode with some slots using the scan engine?
02-02-2024 04:28 PM
Yes, you will only write FPGA code for the cRIO cards you want, all the others should run in the scan engine hybrid mode.
