10-12-2007 03:15 PM
10-15-2007 10:34 AM
Hello.
Thank you for posting to the NI Discussion Forums.
I would recommend taking a look at the following knowledge base article (KB). It seems to answer your question or at least give a few good troubleshooting steps to take. It is interesting that the behavior is not seen on XP while it is seen on NT. My thought here is that the XP system probably executes commands much faster than the NT machine and thus is not seeing the conflict described in the KB. Have you ever had the code working on an NT machine without this fault?
Why am I Getting "PCI-MXI-2 Error -1073807298 or System Hang" with VXI?
http://digital.ni.com/public.nsf/allkb/3688705B6D2A405486256E9F005953F6?OpenDocument
Let me know if this helps!
Brian F
Applications Engineer
01-28-2008 04:12 PM
01-29-2008 05:41 PM
Can you elaborate a bit on the behavior you are seeing? To clarify, communication is working correctly until viMoveln 16 is called, is this correct? Are you seeing any error codes? Does Resman run successfully? Also, what versions of NI-VXI are you using and what hardware are you using? Thanks!
Ted
01-29-2008 07:19 PM - edited 01-29-2008 07:20 PM
No communictions problems until a block move is done.
Resman runs consistantly without error.
NI Spy shows no errors.
I've tried NI-VXI 3.2 and 3.3.1.
Intel P3 2.6 GHz PC with Windows NT4 sevice pack 6.
I have a hunch that the PCI-MXI 2 card is not using DMA even though the hardware configuration says it's enabled because I've seen the block move hang on other systems when the card's DMA is disabled, but I don't know exactly how to test that hypothesis in NT.
01-30-2008 05:07 PM
01-30-2008 08:02 PM - edited 01-30-2008 08:12 PM
02-05-2008 04:20 PM
