I loaded 3.0. I can now take measurements with no problems. If I run self test, the soft front panel will eventually lock after a few tries. It is not perfect, but got me to the point where I can make it function. Thank you.
On 2.1.1, I could set up hardware on the MXI-2 card. One of the settings was the IRQ which I could set for IRQ1. I could not find the way to do this and the help indictated that I should go to a menu that does not exist. HOW DO I SET IRQ using 3.0?????
