02-04-2009 04:14 AM
I have two VXI Mainframes and use two VXI-MXI-2 boards connected. My OS is VxWorks 5.5 running in VXIpc874B. After running resman, it must show borads in two mainframes. but it usually show boards in first mainframe. I try to run resman several times. Sometimes, the boards of second mainframe apear again. When the boards of second mainframe disapear, the second VXI-MAI-2 disapear too.
How do I configure my system?
02-04-2009 08:41 PM
http://sine.ni.com/kb/main/p/sb/navsRel?q=NI%20VXI-MXI-2
http://digital.ni.com/public.nsf/allkb/F09CB807E492FAE8852563D500648EAC
Try above first.
Also you can contact Taiwan local branch directly.
NITW AE
02-05-2009 08:38 PM
Hi Fatty,
Thanks for your reply.
I want to clearly my problem. My problem is after vxworks boot up and run the resman, I can only saw the first mainframe's VXI-MXI-2 and my system does not hung up. it works perfact. If I run resman again(maybe serval times), I can find the second VXI-MXI-2 which is in the second mainframe. That's my problem.
I want to simplify my problem. May someone can help me to check the hardware setting first. I will list my setting in seprate reply.
02-05-2009 08:41 PM
MyController(VXIpc874) is in Mainframe 1 and LA is 0
1st VXI-MXI-2 in Mainframe 1 2ed VXI-MXI-2 in Mainframe 2
LA 1 128
S2 Off Off 50 Terminal for External Trigger Input
S3 Out Out SMB CLK10 Direction
S4 Off Off 20 Terminal for SMB CLK10
S5 Inverted Inverted SMB CLK10 Output Polarity
S7 Drive CLK10 out MXIbus Receive CLK10 from MXIbus
S8 No No VXI-MXI to left
S9 No No VXI-MXI to right
W2 Auto Auto
W3 From onboard oscillator From MXIbus
U35 - 1 Yes Yes Terminal MXIbus
U35 - 2 Yes Yes Automatic MXIbus Terminal
U35 - 3 No No Change Factory Configuration
U35 - 4 No No Restore Factory Configuration
I referance these configure from the VXI-MXI-2 User Manual. I am not sure if lost some setting.
Another question. Is any sequence to power on the mainframe? Does first mainframe need to power on first or second one? Or never mind this.
Thanks if anyone can check my problem.
02-11-2009 11:38 PM
Will you send your information to support.taiwan@ni.com.
Maybe we can arrange on-site support.
NITW AE
02-12-2009 09:12 PM
02-16-2009 11:13 PM
Can I know how are you running resman? Are you using a host PC with Windows? Are you configuring your system visa Remote Systems Measurement and Automation software?
If you are, would you take a screenshot showing when your system can see the first mainframe's VXI-MXI-2 but not the second? Also, take a screenshot when the second VXI-MXI-2 appears appropriately.
Thank you very much,
NITW AE
02-17-2009 07:56 AM
Sorry! I am using VxWorks 5.5 as my OS. And I can not capture the screen for you. Now my solution is do below function after I boot up. I just call resman() until I find my second VXI-MXI-2 module. But I think that is not a good ideal.
long StartupVXIMXI2()
char szExper[] = "VXI?*INSTR";
char szMF2Name[] = "VXI0::128::INSTR";
ViChar instrDesc[MAX_INST_LIST][255];
ViFindList listInstr;
ViUInt32 nInstCnt;
ViStatus status;
ViSession inst;
char szModuleName[255];
unsigned short int nSlot;
long nRet = -1, bFindMF2 = 0;
do {
taskDelay(10);
logMsg("L%d, Searching instrument ...\n", _module_line());
if( status = viFindRsrc(instGetResourceManager(), szExper, &listInstr, &nInstCnt, instrDesc[0]), status < VI_SUCCESS ) {
printf("ERR %d, viFindRsrc('%s') fail\n", nRet = _module_error_code(), szExper);
break;
logMsg("L%d, %d instruments found\n", _module_line(), nInstCnt);
if( nInstCnt ) {
printf("==========================================\n");
for(int i=0; i<nInstCnt && i<MAX_INST_LIST; i++) {
nSlot = -1;
if( status = viOpen(instGetResourceManager(), instrDesc[i], VI_NULL, VI_NULL, &inst), status != VI_SUCCESS) {
logMsg("E%d, Open instrument %s fail\n", _module_line(), instrDesc[i]);
else {
if( status = viGetAttribute(inst, VI_ATTR_MODEL_CODE, &nSlot), status != VI_SUCCESS) {
viClose(inst);
if( strcmp(szMF2Name, instrDesc[i]) == 0)
bFindMF2 = 1;
logMsg("L%d, %d.%s MODEL %u\n", _module_line(), i+1, instrDesc[i], nSlot);
status = viFindNext(listInstr, instrDesc[i+1]);
if(!bFindMF2) {
taskDelay(10);
instReleaseResourceManager();
taskDelay(10);
resman();
continue;
nRet = 1;
} while(!bFindMF2);
return nRet;
02-19-2009 10:06 AM
Hello Zodicx,
On the Tornado development environment, I would like to see the differences when only one of the VXI devices is detected. Can you let me know what the sysfail lights and sys lights are during these times?
NITW AE02-19-2009 07:17 PM - edited 02-19-2009 07:18 PM
Hello Zodicx,
I hope to get more information from you. Can you provide me the log Resman creates along with the information from the Sys and Sysfail lights.
Also have you checked the mxi-2 cables for any bent pins?
NITW AE
