05-21-2010 04:20 PM
I am looking for data sheets, specs, part numbers, etc. anything concerning the cables required to connect PCI-MXI-2 (144 pin square connector) to MXI (62 pin D connector)
I may be blind or stupid, or quite possibly both, but I have had no luck locating this info on the NI website.
Any help is greatly appreciated.
Don
05-24-2010 10:15 AM
Hi Don,
There is no way to adapt a MXI cable from one generation to another. All equipment from a MXI Kit should be limited to the same generation. Post back if you have more questions. Best of luck to you!
05-24-2010 01:01 PM
Thanks for the reply.
That's not very encouraging, but luckily I found the info I need elsewhere.
Don
