I am looking for data sheets, specs, part numbers, etc. anything concerning the cables required to connect PCI-MXI-2 (144 pin square connector) to MXI (62 pin D connector)
I may be blind or stupid, or quite possibly both, but I have had no luck locating this info on the NI website.
There is no way to adapt a MXI cable from one generation to another. All equipment from a MXI Kit should be limited to the same generation. Post back if you have more questions. Best of luck to you!
