09-24-2004 08:31 AM
10-07-2004
06:03 PM
- last edited on
07-11-2025
02:57 PM
by
Content Cleaner
Hi John,
Answer 1:
By definition, the MXI cards should function transparently. From ni.com and our internal documentation:
MXI-3 is a PCI-PCI bridge that is used to expand the PCI bus. MXI-3 is the successor to MXI-2 and MXI-1. Because this is a PCI-PCI bridge, it is completely transparent to the OS and to your program
While the above definition is regarding MXI-3, it fully applies to MXI-2.
Answer 2:
The PXI and PCI bridge cards' software include different versions of NI-VXI/NI-VISA. All the specs I saw online listed them coming with older versions of the drivers, ie for Windows 95, 98, and NT. If this is the case, then you'll want to download the latest version of the NI-VISA driver (3.3.1) from ni.com. The latest driver should ship with your card,
but if for some reason it doesn't, downloading it will take care of you.
Most Current VXI Drivers
Hopefully this is enough information to get you on your way! Good luck!
10-08-2004 06:07 AM
10-08-2004
10:06 AM
- last edited on
07-11-2025
02:58 PM
by
Content Cleaner
Hi John,
Thanks for your reply. Before I respond to your new question, I need to clear something up from my previous response. I misunderstood what you were asking, and posted some information that needs to be clarified.
MXI-3, while a successor to MXI-2, is quite different from MXI-2. MXI-3 is a PCI to PCI bridge , where MXI-2 is a VME to VME bridge. Also, MXI-2 requires the proper driver to function correctly.
For more information about the differences between MXI-3 and MXI-2 see the KnowledgeBase article, Upgrading VXI Systems from VXI-MXI-2 to VXI-8340 Series (MXI-3)
For the current driver required for MXI-2 to function with your
operating system, refer to Current NI-VXI Driver Versions
However this does not change the fact that you CAN replace the PCI-MXI-2 controller that shipped with your Zygo system with a PXI-MXI-2 controller.
As far as working around Zygo's use of the 2.1.1 driver goes, you could try to get your PXI system to work with the 2.1.1 driver. By all that I can tell, the 2.1.1 driver was developed to support PCI-MXI-2 on several operating systems, including Windows 2000, NT, ME, 98, and 95, and so you would need to be operating under in one of the supported operating systems in order for the driver to even be a possible solution. So, assuming you are using a supported operating system, I would download that 2.1.1 driver and install it in your system, and go from there. You can get directly to PCI-MXI-2 driver for Windows by clicking here.
Hopefully this gets you going, but let me know what ends up happening. Good luck!
Logan S.
10-11-2004 03:42 PM
01-13-2005 03:43 PM
