USRP Software Radio
cannot receive signal from channel 1 using example of niUSRP multiple Synchronized Output (MIMO Expansion)
Hi everyone. I need some help regarding receiving using USRP N210 for Multiple Output (MIMO Expansion)
I actually try run the example from niUSRP EX TX Multiple Synchronized Outputs (MIMO Expansion).
When I try to receive the signal, i only receive signal transmitted from channel 0 as attached in the figure here (MIMO Receiver).
I did not modify the block diagram.
I use USRP N210 to transmit and receive.
Does anyone know why is it so? Is it because the antenna? I am
Message 1 of 1
(959 Views)
