04-23-2019 07:46 AM
my SystemLink cloud license expired can I able to read or write the tags already existed ?
04-24-2019 04:56 PM
In what context are you using SystemLink Cloud? Are you able to acquire licensing for it?
04-24-2019 09:35 PM
i am accessing SystemLink cloud services from the link https://www.systemlinkcloud.com/. I have some build apps that are running in the server. when I open this page normally it is not giving any notification. when I open the web apps it is showing your licence will expire in 2 days. I want to read or write the tags from that page by using myrio for my project. at present I don't want my application to run in webserver. I can run the application using LabVIEW NXG. can I able to read or write the tags?
04-25-2019 10:34 AM
You mentioned that you're using a myRIO. Are you a student? If so, you should reach out to your university. They most likely have licensing that you could use that would give you access to SystemLink Cloud.
04-25-2019 11:57 AM
Yes, Thank you for your help. I will contact my college for the license. just to know that I am asking weather can I able to read or write the tags already existing if license expires.
04-25-2019 01:43 PM
I don't think it will work once your license expires.
04-27-2019 03:45 AM
yes, i am not able to see my web applications it is asking to activate but my previous application is still running when i open the pervious link. it was displaying what ever I had designed.
Thanks for the help.
