02-11-2009 12:33 PM
02-11-2009 01:00 PM
Hi Jason,
You could use the Switch Soft Front Panel (right-click on the switch module in MAX and select Test Panels...), but since you've already configured a route group (and thus I assume you're using NI Switch Executive), you can use the NI Switch Executive Test Panel!
In MAX, select the NI Switch Executive Virtual Device of interest (i.e. SwitchConfiguration1). In the menu above the NI Switch Executive user interface, click "Test Panel..." The test panel allows you to connect/disconnect the routes and route groups in the Virtual Device. You can even launch the Switch Soft Front Panel!
Let me know if you have further questions. Best regards!
Chad Erickson
Switch Product Support Engineer
NI - USA
02-11-2009 03:20 PM
02-12-2009 08:21 AM
Hi Jason,
You can add the routes you want to open (a subset of the routes in the connected route group) in a route group. Disconnect this route group and you'll obtain the functionality you are looking for. Later, be sure to either a) connect this route group before disconnecting the original route group, or b) disconnect all.
Let me know if this helps - thanks!
Chad Erickson
NI - USA
