02-16-2009 05:53 PM
When using the SCXI-1127 in the 2 wire mode configuration, will it be using only the 32 relays located in the left bank of the PCB?
I am trying to measure the path resistance in this configuration, but I need to identify the relays used in this configuration. The PCB has a total of 45 relays distributed in two banks, can you confirm with me that only the 32 on the left bank are being used in the 2 wire mode configuration?
02-17-2009 11:38 AM - edited 02-17-2009 11:39 AM
Hi maggan,
To answer this specific question and related inquiries, I strongly recommend the NI Switches Help (installed with the NI-SWITCH driver). Download the Help by itself using the following link:
NI Switches Help
http://digital.ni.com/manuals.nsf/websearch/B133DDD29F0DFCC28625746E00564E56
The relay replacement section is a great resource for information such as which relays are used to connect a particular channel to COM. In the attached picture, I've outlined the relays used to connect ch0 to com0 in the SCXI-1127's inherent 2-Wire 32x1 Multiplexer Topology.
Let me know if you have further questions!
Chad Erickson
Switch Product Support Engineer
NI - USA
02-18-2009 11:56 AM
Thank you Chad,
This gave me the answer I was looking for. I have downloaded the help file before, but I can't access the content, so it's been useless for me. But your diagram gave me the answer I was looking for. Thanks again!
Maggan
02-18-2009 12:28 PM - edited 02-18-2009 12:29 PM
Hi Maggan,
Yeah, I was so excited to show where you can find the information that I forgot to answer your specific question. As you already know, the answer is that most of the relays are used, not just the 32 on the left bank.
I'm curious as to why you can't access the content. If you're willing to elaborate, then I'll do my best to help!
Chad Erickson
NI - USA
02-18-2009 02:22 PM
Hi Chad,
I got it now! I needed to modify my internet settings to allow the help file to access the content. Thanks for your help! 😃
Maggan
