05-19-2006 07:33 AM
05-19-2006 04:53 PM
05-22-2006 01:07 AM
Hello Srdan,
You are absolutley right the region Bodensee is a really nice place.
But now don´t lets talk about this place.
Thank you very much for your help information. I thought it might could
be done with #import. Like if you know, with the TestStand API.
But I never, never! found tlbid(2) attribute. So thanks again.
Greetings
Juergen,
Hm! You saved a lot of time for me, so I should go to lake
and drink a "Weizenbier" for you.
05-24-2006 08:17 AM
05-24-2006 10:12 AM
05-24-2006 11:07 AM
Juergen -
I tried calling calling the COM API using TestStand ActiveX/COM steps and they worked fine from a regular TestStand Execution thread that uses multithreading by default.
This is not a recommended solution, but if this is a threading model issue, one option to try is to force a TestStand thread to use a single threaded apartment when executing your steps. To do this add your steps that will access the NISE API to a separate sequence. Add a Sequence Call step to invoke that sequence. Specify to run the sequence in a separate thread and specify that to use single threaded apartment. Make sure that you set to wait on the thread.
The next step after the above would be for you to possibly share your project and code for someone to look at.
11-04-2008 03:39 AM
Hi
I want to use NISE to handle switches.
I want to make a C/C++ application.
I want to receive a path with a NISE Configuration file and see that file to make the connection.
I don't know what functions can i use to get the routes from the VirtualDevice that i import with niseCfg_Import
CAn anyone help me?
