11-25-2008 08:43 AM
11-25-2008 09:06 AM
Hi Jason,
Is it possible to have 3 rows set as reserved for routing and to connect the 3 endpoints to the remaining row?
Chad Erickson
Switch Product Support Engineer
NI - USA
11-25-2008 09:10 AM
11-25-2008 09:22 AM
Hi Jason,
Are you using NI Switch Executive 3.0? This version supports the sharing of route legs.
http://joule.ni.com/nidu/cds/view/p/id/1059/lang/en
Hope this helps!
Chad Erickson
NI - USA
11-25-2008 09:39 AM
11-25-2008 10:12 AM
Hi Jason,
I'm assuming that you're using NI-Switch 2.3. To my knowledge, NI Switch Executive was only released with the following versions: 2.0, 2.0.1, 2.1, 2.1.1, 3.0.
The option you listed is not your only option, but it is the option that I recommend for prior versions of NI Switch Executive. Remember that you can use Route Groups to store the separate row to column connections so that only one connect call is required.
An additional option you have is to use two NI Switch Executive Virtual Devices. One Virtual Device has the PXI-2532 rows reserved for routing and the other Virtual Device doesn't. Each time you want to connect multiple columns to the same row, you could close the session to the "reserved for routing" Virtual Device and open a session to the other Virtual Device (where you connect multiple column endpoints to the same row). Note that you cannot have sessions open to both Virtual Devices at the same time because they would attempt to share the same hardware.
Is upgrading to NI Switch Executive 3.0 a possibility? There are two additional features you would enjoy:
It would be great if upgrading were an option. Let me know if you have further questions!
Chad Erickson
NI - USA
11-25-2008 10:22 AM
