Signal Generators
square wave with USB 6001 or 6002
Can I generate a hardware timed, 100 Hz square wave with a USB 6001 or 6002?
Message 1 of 10
(13,003 Views)
Hello salty,
The specification document for both devices (found at the links below) indicates that hardware timed analog output is possible on both devices.
SPECIFICATIONS NI USB-6001:
http://www.ni.com/pdf/manuals/374369a.pdf
SPECIFICATIONS NI USB-6002:
http://www.ni.com/pdf/manuals/374371a.pdf
Each device supports a maximum update rate of 5 kS/s simultaneous per channel, hardware timed. Therefore, you should be able to generate a hardware timed 100 Hz square wave using either device using an analog output task.
J_Bou
Message 2 of 10
(12,983 Views)
Thanks J_Bou,
Thanks for the information and the confirmation. I was able to use one of the examples to produce the square wave.
Message 3 of 10
(12,970 Views)
 with this devices can you get frecuency about 5000 Hz?
Message 4 of 10
(12,679 Views)
I tried to generate a 5 kHz signal but was only able to generate up to 2.5 kHz.
Message 5 of 10
(12,666 Views)
Hi, you used a Square Waveform VI or something else?
Message 6 of 10
(12,659 Views)
