Signal Generators
Data out of range; offset;value clipped to upper limit.
Hi all,
I am using Agilent 33510B series Signal Generator and below is the requirement which I am trying to setup for both the channels,
Channel1:
  • Waveforms: SINE
  • Parameters à Frequency: 100kHz
  • Parameters à Amplitude: 2.000 mVpp
  • Output Load: High-Z
Channel2:
  • Waveform: DC
  • Parameters à DC Offset: +10.00 V
I have downloaded the necessary drivers from NI and when I try to run the code, I am facing an error -1074000000 and which explains as show below,
Error -1074000000 occurred at Agilent 3352X Series_3301B.lvlib:Error Query.vi
Possible reason(s):
Instrument reports:
-222,"Data out of range; offset;value clipped to upper limit."
+0,"No error"
Complete call chain:
     Agilent 3352X Series_3301B.lvlib:Configure Standard Waveform.vi
     Verify Initial Frequency.vi
I have set the same configuration for both the channel and for channel1 there is no error and for channel2 there is no error while writing to VISA function but facing an error while using the Error Query.vi which generates the error -222.
And I checked the instrument datasheet that Agilent 33510B -> Channel2 supports DC Offset voltage as 10V.
Kindly share some steps to be followed to resolve this error.
Thanks in advance.
Karthik
Message 1 of 1
(686 Views)
