Signal Generators
Capability of NI PXIe-5443 FGEN Card to Generate DC Signals
We need to run some tests that require a steady DC signal up to 2 volts. We're planning to use the NI PXIe-5443 Arbitrary Waveform Generator (FGEN) card for this purpose. However, we're not sure if this card can generate a stable DC signal. Could you please confirm if the PXIe-5443 can produce a DC signal at the required voltage? If it can, any advice on how to set it up correctly would be very helpful.
(623 Views)
Accepted by KingstonLeo13
Certainly, an "arbitrary" waveform generator can generate a steady DC signal, as DC signal is still "arbitrary."
If you use LabVIEW, open this example from the Example finder.
Use "DC" as the Standard Waveform option.
Santhosh
Soliton Technologies
(592 Views)
