Real-World Applications
NI cRIO 9024 with the Quanser Rotary Inverted Pendulum
Dear ,
I am trying to connect the cRIO-9024 with the Quanser Rotary Inverted Pendulum(RIP), using LabView 2013 SP1. The connection with the RIP using cRIO-9024 has been connected or Deployed. When I run the code, I received the following error.
Possible reason(s):
Support for the given board type does not appear to be installed. Verify that you have selected the correct card in the HIL Initialize block or hil_open function.
Complete call chain:
Quanser RCP Utilities.lvlib:Error Cluster From Quanser Error Code.vi:4130348
HIL Board.lvclass:HIL Open.vi:370005
subHIL Initialize.vi:6230004
ROTPEN Control.vi:Instance:0:480001
ROTPEN Control.vi
Please guide me, if possible.
Thanks and Regard
Furqan Memon
Comments
Jeremy_T
on
Hello Furqan
This section of the community pages is intended for NI hardware and software users to post papers about their completed projects.
You're most likely to find the help you need by instead posting on the discussion forums here: https://forums.ni.com/t5/Discussion-Forums/ct-p/discussion-forums
The discussion forums are active with programmers and engineers who may have solved issues like yours.
Best regards
Jeremy
Jeremy T
Technical Marketing
NI
