02-24-2020 08:36 AM
Hi everybody,
I need to use in RT an usb 3 camera installed on a PXIe-8840.
When I directly work on the PXI in windows (no RT), the MAX correctly recognize the camera and I can use it in LabView. But when I work in RT (with labview real-time 19.0) through an host pc, the MAX does not see the usb 3 camera on the target.
I installed on the target the NI-IMAQdx driver, but there I only see the "GigE version camera support". Anyone knows if there is any possibility, or any other driver I should install, to use an usb 3 camera on PXI platforms in Real Time?
Thank you
03-03-2020 08:31 PM
I don't believe USB3 Vision camera in NI LinuxRT is supported unfortunately.
08-12-2020 05:35 PM
I was trying to do the same. Did you find a way to do it?
08-18-2020 02:30 AM
no, apparently there is no way with an usb camera. GigE camera is the only solution
