Thanks for the Input. I changed the IP settings on the CRIO to DHCP, and everything started working. Apparently, when I use a Fixed IP, I don't have the subnet mask, Gateway and DNS settings correct, and it's causing networks errors that allow me to see the machine, but not work properly. The network settings are picker for the CRIO, then say, a dumb network device like a Ethernet to Serial Port Converter, which only needs an ip address. Setting a fixed ip address isn't enough on a complex corporate network.
Raltieri
