Veristand FPGA: Can't acquire analog input
Hi everyone,
I have a problem acquiring analog data with my PXIe-7847R with the SCB-68A terminal block. I'm using a PXIe8840 Quad Core controller with a PXIe1084 chassis. I'm using LabVIEW 2020, VeriStand 2020 and the LabVIEW FPGA Module as well as the NI VeriStand FPGA module.
First, when I use the LabVIEW FPGA Module, I can easily acquire analog input data from a power supply. But when i'm trying to acquire analog data from VeriStand using the NI VeriStand FPGA Module, the values of my Analogs input channels are wrong. Weirdly, even if I can't acquire the wright analog input value, the analog outputs channels are working properly. I have wired AI0+ and AI0- to my power supply (set to 1V DC).
Knowing that my wiring seems okay because I can acquire analog input data on LabVIEW using the LabVIEW FPGA project template and that my NI VeriStand FPGA VI seems also correct because I can generate an analog output voltage, what could be the possible reason of my problem?
Message 1 of 1
(858 Views)
