10-10-2017 07:51 AM
Hi ,
I have a set of data that is acquired from a sensor using USB 8452. I collected the data in excel sheet .I want to remove the noise signal and find out the sensor output.
I attached the excel sheet with this forum.
Solved! Go to Solution.
10-10-2017 09:33 AM
So this is a post-processing issue, not an acquisition issue.
Filtering can take many forms, the simplest being a moving average (look at the Mean PtByPt VI).
10-12-2017 04:05 AM
thanks for your reply.
I Tried that also, but I cant get the correct value.I enclosed the vi file .
10-12-2017 06:28 AM
What does this VI have to do with filtering? I just see string to number conversions (which could be greatly simplified using Unflatten From String and/or String To Byte Array). What do you expect for an output with this input?
10-12-2017 09:13 AM
hi
I need the correct sensor output.I acquired the signal but it is not clear to get the correct acquired value due to noise.
I need to calibrate my sensor. I acquired the signal through I2c mode using USB 8452. How can I fliter the noise signal and acquire the correct output value from the input. ?
Can you help in this concept?
10-12-2017 10:27 AM
If you are not even sure you are getting the right values from the sensor, we need to look at that first. What sensor are you using? Do you have a data sheet? Can you share your acquisition code?
