09-05-2022 04:41 AM
Hi everyone,
I had those two old cards in an old WinXP PC working just fine.
Now I need to get them to a newer PC.
It's hard enough trying to find one with a motherboard that has 2xPCI.
Will I have any other compatibility problems?
Do I need a 32bit PC? Maybe, a 32bit Windows version?
Please help!
09-05-2022 11:43 AM
You can install it on any computer that has a PCI slot. In terms of software support, you need to check if there is a DAQmx driver that supports 6250 and 6733 for that OS version.
09-06-2022 02:01 AM
Thank you for your answer!
Luckily, I found that it supports drivers that can run on Win10 (15.5 and later).
