10-30-2020 04:07 AM
In the development environment, I found that this frame has a timeout every 38 to 40 seconds.
However, after I downloaded and deployed the real-time program to PXI (components : PXIe-1082 chassis, PXIe-8840 controller, PXIe-6738 and PXIe-4497 card), I estimated that this frame also timed out, which showed that the time required to see the signal trigger increased slowly (as shown in the figure 2, there was a deviation of 0.6 ms in about 4 minutes); I want to solve the problem of frame timeout, but it will what is the reason for this?
Thank you in advance for checking and helping!
11-08-2020 01:06 PM
Hello
By saying timeout you mean that program gives timeout error?
Also, I noticed DAQmx run vi in the timed loop (at the bottom), this is not usual and right way to start the acquisition/generation.
11-15-2020 07:32 PM
