09-18-2017 08:00 AM
i'm designing a IC-3173 based vision gear, that i want to be as simple to use as possible. Therefor i plan to use a tactile monitor as the only UI, to interact with the application front panel. But as i'll choose the NI-RT Linux version (because i need real time capabilities), i wonder if the driver for such monitors exist in this OS...Had anyone already make such a configuration properly work ? Will it work for the image indicator tools (magnifier, ROI tools, etc) ?
09-19-2017 04:18 AM
Hi VdG,
What is the reference of your monitor ?
Thank you
09-19-2017 06:12 AM
Hi maxime,
i don't have any reference yet. I saw many tactile monitors with display port input on the web. Do you expect some of them to have linux driver while others haven't ?
