This plugin inserts selected VIs into selected wires. Multiple VIs and multiple wires may be selected. It does the same action as the Insert quick drop, but for VIs that are already on the block diagram.
Put the attached folder into your <LabVIEW>\resource\dialog\QuickDrop\plugins folder
Press Control-Space, Control-s
Optionally, you can press Control-Space, Control-Shift-s to prevent the selected VIs from auto-aligning, which is the default behavior
