12-19-2014 11:17 AM
You can right click a class object and choose "Show Class Library" but sometimes, all you have is a class wire going between two nodes. You used to have to right click the wire, create a constant, and then right click the constant to show class library, but now you can just select the wire, and this quick drop shortcut will open the class.
Use:
Select class wire, terminal, constant, or control. Or select a subVI with a class terminal.
If nothing is selected, it will try to open the current VI's library.
Default Shortcut - o. (for open class)
08-13-2018 04:05 PM
I made it into a shortcut menu plugin and added the ability to operate on either a subvi terminal or a wire (LV2018).
08-14-2018 01:22 PM
Freaking awesome! Will use it and recommend it to everyone! KUDOS
08-14-2018 02:16 PM
Is it possible to downconvert it to LV2015, to install it across other LV versions?
08-14-2018 02:58 PM
Yes, no problem. I don't have 2015 to test with though. If I recall correctly, there might be a small issue with "separating compiled code" so if the shortcut doesn't show up, you might want to uncheck that box.
Also, I was thinking that it should be possible to extend this so you can click on a wire with a type definition and open the .ctl. I'll put that on my "to do" list.
08-14-2018 02:59 PM
08-14-2018 11:58 PM
08-15-2018 02:13 AM
Cool plugin!
What would be also nice, is to have there additional option to open Parent Class library - I guess, it'll be also handy.
What do you suggest, please? Is it possible to add it there?
Thanks a lot,
Sincerely, kosist90
08-15-2018 06:21 AM
You might want to post this plugin in the LabVIEW Shortcut Menu Plug-Ins board.
