09-09-2014 01:18 PM
This shorcut inverts the visibility of the selected controls and indicators (usually to make them hidden).
Holding shift will cause all controls and indicators on the front panel to be made visible.
Default shortcut - V
[update 6/15/2015] - now works from the block diagram as well, select the terminals of the controls / indicators you want to toggle visibility of.
09-09-2014 01:30 PM
FYI, when you right click on the terminal of the hidden control/indicator on the block diagram you have to option to "Show Control\Indicator"
09-09-2014 01:35 PM
ah, there is is . I got frustrated by double-clicking the teminal, which highlights the control on the front panel, and as soon as I right clicked, it would disapear again.
thanks for the tip, perhaps I'll tweak this shortcut to make it more useful...
06-15-2015 05:36 AM
@Alex5 When I use this shortcut the visibile property of Control/Indicator is not changing. I am using LV-2014. Would you please check this?
06-15-2015 09:16 AM
you have to select the controls / indicators on the front panel that you want to make invisible. If you want to make all controls / indicators (and not just the selected ones) visible, hold down shift while applying the shortcut.
06-15-2015 11:01 AM
I am out of the office until 06/16/2015.
No phone or email access.
Note: This is an automated response to your message "Re: [Quick Drop
Enthusiasts] - Quick Drop Keyboard Shortcut - Control Visibility" sent on
6/15/2015 4:36:28 AM.
This is the only notification you will receive while this person is away.
