Quick Drop Enthusiasts
How to install a Quick Drop Keyboard Shortcut plugin
There are two locations from which LabVIEW loads Quick Drop Keyboard Shortcut plugins.
[LabVIEW 20xx]\resource\dialog\QuickDrop\plugins
  • Plugins installed here are only accessible in that version of LabVIEW.
  • These plugins are available to any user logged in to the computer.
  • Save the plugin VI(s) in this LabVIEW version to improve load time performance of the plugin.
[LabVIEW Data]\Quick Drop Plugins
  • You can use Tools > Options > Paths > Default Data Directory to find out where the LabVIEW Data folder is on your system.
  • Plugins installed here are available in any LabVIEW installed on the system that is equal to or newer than the version used to save the plugin VI(s).
  • These plugins are available only to the user account that contains the LabVIEW Data folder.
If you are using a package management tool like VIPM, it makes the most sense to install Quick Drop plugins to the LabVIEW 20xx folder. If you are manually installing a plugin and want to share it across different instances of LabVIEW, you should install it to the LabVIEW Data folder instead.
(5,621 Views)
Hi Daren,
Do you know where are the shortcuts installed? I would like to automate the assignment of each shortcut to the correspondent plugin during the VIPM install.
Guillermo Oviedo
R&D Software Engineer
CLA | CTD
(4,658 Views)
Oh never mind,
If someone else is looking for this, check this KB:
Boost labview productivity with quick-drop
Guillermo Oviedo
CLA | CTD
(4,654 Views)
The keys for each type of shorcuts are:
  • QuickDropDiagramShortcuts
  • QuickDropPanelShortcuts
  • QuickDropKeyboardShortcutMappings
Guillermo Oviedo
CLA | CTD
(4,628 Views)
