PXI
mxi-4 pinout
Where can I find pinout for MXI-4?
Message 1 of 8
(4,684 Views)
Hi, Transport,
here you are the pinout:
Pin 1 on PXI side: Tx+ -> pin 5 on other side.
Pin 6 on PXI side: Tx- -> pin 9 on other side.
Pin 5 on PXI side: Rx+ -> pin 1 on other side.
Pin 9 on PXI side: Rx- -> pin 6 on other side.
The MXI-4 link has a DB9 connector which has only four pins populated.
Saludos!
Jesús
Message 2 of 8
(4,657 Views)
Hola Jesús,
Do you happen to know the impedance of the cable used for MXI-4 connections?
Muchos gracias,
Alex
Message 3 of 8
(2,160 Views)
The short answer is 150 ohms.  It was discussed a little here:
https://forums.ni.com/t5/PXI/Custom-cabling-for-MXI-4/td-p/4025802?profile.language=en
Message 4 of 8
(2,156 Views)
Hello Robert,
It looks like the specification is very similar to these Fibre Channel cables made by Amphenol:
https://cablesondemand.com/product/CS-FCDB9X2MM0/URvars/Items/Library/InfoManage/CS-FCDB9X2MM0.htm
Thank you for your help,
Alex
Message 5 of 8
(2,148 Views)
Hello Alex and Robert,
Are there any products out there that are a 1-1 replacement for these MX-4 cables ?
I've bought one that looks right but if there's a direct replacement I'll get one of those instead.
These cards seem to be easy to get secondhand but the cables are a rarity.
Cheers
Jamie
Message 6 of 8
(1,100 Views)
Hello Jamie,
I did some research way back when and found that the cable is derived (or equivalent to) a Male to Male 9-way Fibre Channel cable.
The important thing is the cable itself, rather than the connectors. The cable is Madison Cable Corp TurboQuad Gold.
I was able to buy a cable from a company here in the UK:
G. Underwood Ltd
13 Main Street
Keyworth
Nottingham
NG12 5AA
+44 (0)115 937 6706
sales@underwood.co.uk
The person I dealt with, Geoff, had a "Fibre Channel 9 way Male to HSSDC 3m Cable" which they then swapped the HSSDC for a 9 way Male.
You could probably also source such a cable through ebay with carful search terms. Alternatively, you could buy a HSSDC cable and replace the connectors with 9-way males.
Note that unfortunately I think some pins were swapped on the supplied cable, but this was easy enough to correct.
Alex
Message 7 of 8
(1,086 Views)
Hi Alex,
Thanks for your prompt reply! I did find a old fibre channel cable with DB9 male connectors on each end that seems to match the pinout on one of the earlier posts. Its on the way to me via ebay so I'll keep you posted on whether it works. I think the cable might the the same turboquad or equivalent. Fingers crossed!
Cheers
Jamie
Message 8 of 8
(1,070 Views)
