I have 2 RMC-8354 PXI controllers, one which has current code / configuration (controller 1) on it and the other which doesn't (controller 2). I created an image of controller 1 using the NI vi's and then deployed it onto controller 2. When the image has been deployed, the controller reboots twice, the second time it pops up saying that it cannot locate NIHWDBDD.dll. Subsequent reboots give the same error message.
Why isn't this file included in the image? I've tried redeploying the image, but the file is still missing.
I'm using LV 2013 Sp1 (32 bit) - I've attached the code I'm using to build and deploy the images in case I'm the problem!
Al
