PXI
analog output not smooth enough
I have a 6025E card.  The waveforms coming out of the analog out channel of the card are not smooth.  The output displayed on an oscilloscope looks like it is composed of 1ms steps.  Is it possible to have a smoother waveforms?  I'm using a labview RT to generate the sinewave that is passed to the ananlog out channel.
thanks
sam
(3,549 Views)
Hi Sam,
Could you give a little more information about how you are generating the waveform, rate, and clock (external or internal) information?
Thanks!
Micaela N
(3,536 Views)
Sam,
Additional information on your application that Micaela is asking for would be helpful to see if there is a way to better the output behavior. What is the waveform shape, frequency and update rate of your board. Additionally, have you looked at the Function Generators from NI? These are made for more precise waveform generation than is possible with a multifunction DAQ device.
-Adam
(3,524 Views)
Thanks for the response Micaela....problem solved, just a bad VI setting.
thanks again
Sam
(3,517 Views)
Great to hear Sam, good luck with the rest of your application!
Micaela N
(3,513 Views)
