12-06-2024 04:41 AM
Hi Guys,
Now I am building project use 272x custom in veristand.I only change value from 0 to 65 om. How to change value geater 65om?
Thanks and Best regards
Hoang Dung
12-06-2024 06:57 PM
Are you using NI-272x-Resistive-Simulation-Custom-Device?
Which model of resistive switch are you using?
12-06-2024 07:34 PM
Hi Zyong,
I am using model as below for 2727
12-07-2024 09:14 AM
Using a simulated device, I don't have any issue setting up to 16320 ohm.
12-09-2024 02:22 AM
Hi Zyong,
for display on Veristand, It still true but when i measure actual, it is not correct. It only max 63.5 Ohm
12-10-2024 06:00 AM
Try using the Test Panel in NI MAX to see if it is a hardware issue.
