11-29-2024 05:57 AM
I have a PXIe-1062Q chassis connected with PXIe-8360 mother board and I am trying to control GX5292-H Marvin Card but I got error code like "No Board Found" i try to connect with other PXI chassis and it work fine. I think the PXIe-8360 and PXIe-1062Q not compatible but I am not sure. Can you tell me what might be the problem?
11-29-2024 06:53 PM
When you said it worked fine with other PXI chassis, are you using the same PXIe-8360 MXI controller, GX5292-H card and host PC?
12-05-2024 08:03 AM
Yes, same PXIe-8360 MXI controller, GX5292-H board and host. When I use another host, I get an error like "Unable to allocate system device resources" and I thought the problem might be in the BIOS. I upgraded the BIOS and checked if plug and play is working and it was working but the problem is not solved.
