04-14-2020 07:09 AM
Hi all,
I'm looking for a PXI Digital I/O Module compatible with Siemens Function Module :
- FUM210-6DP1210-7AA
- FUM211-6DP1211-7AA
Any help please.
Ahmed
04-14-2020 10:09 AM
It would be good to share the datasheets so that we can look into the number of digital lines required.
In general, these information are required to choose the PXI card,
04-14-2020 12:52 PM
hello,
I can't find the data sheet online for these modules, i have only the description below :
-MODULE FUM 210 FOR SENSOR CONDITIONING FAST BINARY SIGNAL ACQUISITION, OR DRIVE CONTROL SENSOR, MONITORING AND SIGNAL. MODULE CONDITIONING: 14 CHANGEOVER OR 28 SINGLE CONTACTS WITH SENSOR SUPPLY AND MONITORING, 28 BINARY INPUTS WITHOUT SENSOR SUPPLY + 16 BINARY OUTPUTS DRIVE CONTROL: 5/8 MOTORS, 5/8 SOLENOID VALVES 4/5 ACTUATORS, 3/4 STEP CONTROLLERS, 2/3 REVERSING ACTUATORS, REDUNDANT USE POSSIBLE, SIGNALLING AND MONITORING FOR SIGNALLING CONTACS OF THE CABINET, OUTPUT OF GROUP ALARMS
MODULE FUM 211, BINARY SIGNAL COUPLING MODULE 16 BINARY INPUTS WITE ELECTRICAL ISOLATION VIA OCTOCOUPLERS 16 BINARY OUTPUTS 250 MA (WITH LIMITATION) STEADY OR FLASHING (8, 2, 0,5 HZ) SUITABLE TO CONNECT CONSOLE CONTROL TILES. CAPABLE FOR 2 DESK TILES USE IN SPPA-T200
