PXI
PXI-8517 Pin definition
Why I can't  find the pin definition of PXI-8517? Who can provide it, thanks!
(997 Views)
Accepted by bhyy
NI XNET help file documents the pinout - https://www.ni.com/docs/en-US/bundle/ni-xnet-20.5/page/nixnet/flexraypinout.html
PCI and PXI FlexRay Interface
The following table describes the CAN DB-9 pinout on PCI and PXI FlexRay interfaces, such as PCI-8517 and PXI-8517.
Pin Signal Signal
1 NC No connection
2 FlexRay A BM FlexRay channel A bus minus
3 COM FlexRay reference ground
4 FlexRay B BM FlexRay channel B bus minus
5 SHLD FlexRay shield
6 (COM) Optional FlexRay reference ground
7 FlexRay A BP FlexRay channel A bus plus
8 FlexRay B BP FlexRay channel B bus plus
9 (Ext_VBat) Optional external bus voltage
Santhosh
Soliton Technologies
(982 Views)
Thank you very much for your reply!I have another question:Does it means that each port provides two channels of FlexRay bus? When connecting a terminal, use pin2 and Pin7 or pin4 and pin8 all can meet the communication requirements?Thanks!
(926 Views)
